It is currently Sun Nov 22, 2026 2:24 am
 Post subject: Carb trouble
PostPosted: Fri May 18, 2007 10:37 pm
I was adjusting the metering rods and now they get stuck in the up position. Here is the up:
and the down:
Now the problem with the down is that the "levers" seen here:
pinch the "fins" on the mechanism that holds the metering rods:
If I adjust the "levers" high enough that they don't pinch, then the rods lift too high and wont seat back down by themselves. I have to wiggle them around to drop them down again.
help
PostPosted: Sun May 20, 2007 5:57 am
I know how to adjust the rods on a TQ. I didn't know there was an adjustment on the tin top BBD or the older style BBD's.
Can you explain this better?
I just picked up a 77 318 BBD off a 1 ton Maxivian.
PostPosted: Mon May 21, 2007 1:27 pm
Not sure but could it be binding up on the bowl vent linkage? I know I had a booger of a time getting the two meshed back together so both of them worked right. Cant remember specifics but seems it was the same trouble your having that I was having. Trouble with the metering rods working freely and then I noticed it was getting hung up on the bowl vent linkage after I had pulled the rods out at rebuild time and like you was trying to set them back down in and set them back up. It was a tin top Super Six BBD.
Image Image
PostPosted: Mon May 21, 2007 2:23 pm
Only the "tin top" BBDs have adjustable metering rods, the older BBD have the rods hung from fixed position "tangs" attached to the step-up piston.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 9 guests
