It is currently Sat Jun 20, 2026 11:04 am
 Post subject: Need vacuum help!!!
PostPosted: Sun May 20, 2007 8:44 am
I just put a SuperSix 225 (year uknown at present)in an '87 P/U and rebuilt the Carter BBD but all vacuum hoses were capped.I need a diagram for it if possible.Engine has wierd pollution stuff at rear of valve cover with a 'drum-like" apparatus and 1"+metal tubes if that helps date the engine. I bought a new '80 truck and new '86 both w/225's and neither had this setup. This one is in an '87 D100 P/U. Can anyone help???[/i]
Underdoggie and sweet polly purebread hangin' with Jesus!!!
PostPosted: Sun May 20, 2007 9:22 am
One at the back and bottom the largest is the PCV. The vac advance for the distributor is mid way up on the carb body pasenger side.
PostPosted: Sun May 20, 2007 9:23 am
The drum is a vacuum amplifier
PostPosted: Sun May 20, 2007 11:24 am
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Mon May 21, 2007 4:14 am
Thanks!! What really NEEDS to be hooked up????
PostPosted: Mon May 21, 2007 7:53 am
The only things that NEED to be hooked up to the carb are the vacuum advance, PCV and the fuel hose.
PostPosted: Mon May 21, 2007 6:08 pm
Don't run the vac advance to anything but the distributor. Bypass the little gizmatchie on the air cleaner that says "carb" and "distributor" on it. Go direct! :wink:
 Post subject: Vacuum adv
PostPosted: Tue May 22, 2007 9:59 am
There is no Vac advance on this distributor!! Just cap it??
PostPosted: Tue May 22, 2007 1:24 pm
Yes, cap it off. I didn't realize you still had the computer.
