It is currently Sun Nov 22, 2026 3:28 am
PostPosted: Mon May 21, 2007 1:28 pm
I just removed the old I bbl set up from my slant and when I attempted to put on the 2bbl setup the gasket would not line up. The end hole is the problem. I tried to bolt it on and then pry the exhaust against the intake runner but the bolt will only start a bit and then start to strip out.There is a big difference between each side. :cry:
After reading the archives, I was thinking that a set of Dutra Duals may be the ticket. My truck does have a clutch cross shaft, low starter and it is 4WD.
If anybody has any powerwagon that did this conversion or any other info, please let me know. I sent Doug an email but I'm not sure it was the correct address.
Thanks and have a great day to ya all!! :D
Kevin in PA
[/img]
PostPosted: Mon May 21, 2007 2:33 pm
It sounds like your exhaust manifold is warpped which is not uncommon.
I will have to check my email and get you some info on Dutra Duals.
There are no fit problems with the dual cast iron manifolds in your truck.
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 8 guests
