It is currently Fri Jan 02, 2026 3:16 am
 Post subject: Sending unit
PostPosted: Tue May 08, 2007 6:11 am
Anyone know where I can get a new fuel sending unit?
Mine reads full for about 80 miles and then goes to empty.
Thanks,
Superman
1981 D150
"The Khaki Machine"
PostPosted: Tue May 08, 2007 6:38 am
Advance Auto Parts HAS BOTH 3/8 or 5/16 good price to ,hope this helps. Don
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Tue May 08, 2007 8:26 am
Mopar dealer. P/N 4051-004. Or, www.rockauto.com . The correct unit is the one with the 5/16" pipe.
PostPosted: Tue May 08, 2007 1:19 pm
i just bought one from an e-bay store..mine was leakin like a siv
PostPosted: Sun May 20, 2007 5:00 pm
I checked out the store and they did not list one so I guess that I will check with the dealership tomorrow.
Thanks,
Superman
1981 D150
"The Khaki Machine"
PostPosted: Mon May 21, 2007 8:33 pm
I stopped by the dealership and boy are they proud of their sending units.
They wanted $170 just for the sending unit. I asked if it that included it being installed and there was a quick no.
I found a sender with gauge at NAPA for $35.
Who has them online?
Superman
1981 D150
"The Khaki Machine"
PostPosted: Tue May 22, 2007 5:07 am
Hay superman, we now have sending units, all the way to 1/2" outlet. they will be on our site soon. Hope this helps Don http://www.stormcomm.net/moparsnmore/
My Twister Page
PostPosted: Tue May 22, 2007 9:13 am
See my first response to your query in this very thread.
(Why do people even ask questions if they're not going to read the replies they get...?!)
:roll:
PostPosted: Tue May 22, 2007 9:48 am
:roll:
Hi Mister Twister. Just as an aside here. Do you know that your website does not do anything? there is no contact option . Just a static page.Anyway just wondering if you knew.
Charlie///
PostPosted: Tue May 22, 2007 2:22 pm
I did check out the rock auto and they did not have it and so I am still looking.
Still taking the higher road.
Superman
1981 D150
"The Khaki Machine"
PostPosted: Tue May 22, 2007 3:42 pm
This is for your truck? Or some other vehicle?
PostPosted: Tue May 22, 2007 9:58 pm
This is for my truck.
Thanks,
Superman
1981 D150
"The Khaki Machine"
PostPosted: Wed May 23, 2007 5:17 am
:roll:
Charlie///
Hello charrlie. cathi will have it completed soon. PM us is the best way for contact now. hope this helps Don
My Twister Page
PostPosted: Wed May 23, 2007 7:27 am
Ahhhh, that explains why none of the sources you're being given are panning out. You're being given numbers and sources for A-body senders, which aren't the same as truck senders. As far as I know, there's no aftermarket source for these senders; it's a dealer-only item. P/N depends on whether you have a 20-gallon tank ( 4075 252 ) or a 30-gallon tank ( 4075 254 ). Both of those P/Ns are NS-1 (discontinued, no stock, not serviced). The 1983 senders 4075 376 (20-gal) and 4075 378 (30-gal) are still available.
Barring finding a good used one, or having yours rebuilt (this outfit advertises that service in Hemmings) I fear you'll have to bite the bullet and buy an '83 sender and see if you can make it work :-(
PostPosted: Wed May 23, 2007 12:24 pm
It might be possible to fix the truck sender.............
If it's not hard to get out, take it out and see if it's fixable, cleanable, etc........
