It is currently Tue Nov 24, 2026 12:16 pm
 Post subject: Help I.D this 225?
PostPosted: Sun May 27, 2007 9:34 am
"Should" be SuperSix short block, no other casting number than whats shown in pic from drivers side. 030 - 6 and the other *2695*. Stamped in pad are 25R (or F) 2 9 29 and also stamped on another pad is 6 1159
Tried to check from articles page table, but no luck without casting number. It's a 5 freeze plug block, and perhaps '79 but is it?
I can make five mistakes while you think
PostPosted: Sun May 27, 2007 10:28 am
No such thing as a "Super Six block". The Super Six was a US/Canada marketing name for the 2bbl carburetion package; the only different pieces were the intake manifold, the carburetor, the air cleaner, the throttle and kickdown linkages. Block, head, and internal parts were the same.
Can we see a picture of the cleaned-up stamping pad?
PostPosted: Sun May 27, 2007 10:49 am
I know I know Dan... what I meant is that this perhaps leads to late seventies rather than early 60's. It has the correct 2bbl manifold and even air cleaner for super six setup, but I'm after whether the short block is "original" or not, since by the casting the head had changed at some point.
Sorry the stamped numbers are so weak that my camera doesn't catch them
PostPosted: Mon May 28, 2007 12:53 am
Here's the stampings on pad
6 225 R 2929
Does that help any? What's the deal with the fact that theres no casting number?
PostPosted: Fri Jun 01, 2007 2:05 am
Anybody? Anything? Still interested...
