It is currently Mon Nov 23, 2026 5:46 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sun May 27, 2007 1:15 pm
Matt, once you have the timing map done on the dyno, let us know how that went. I would like to know what differences you felt, and also would like to see the timing map, and maybe fueling map they come up with. The fuel map would not be as useful, since the fueling formula utilized by the ECU is most likely not the same. but, timing is timing. That might be the best default, start-up map one could ask for, since our engines are pretty similar in most regards. What rear and trans are you running?
Sam
PostPosted: Sun May 27, 2007 5:42 pm
Sam
Sam,
I'll be sure to post the results.
Right now it has a 904 and a 7 1/4" rear of unknown ratio. I have a 8 3/4"
rear axle with 3.55:1 gears that I will swap in soon.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
