It is currently Wed Dec 31, 2025 1:10 pm
 Post subject: pertronics ignitor ii
PostPosted: Mon May 28, 2007 5:33 pm
I finally got my Pertronix Ignitor II working. Not being a mechanic, the 20 minute job took over a week and a half. Okay, so I got it running before then. I just had some major problems with the timing. And then I got lost there. My stepdad gave me the tip I needed to get back on track.
But the reason for writing is this. My Pertronix Ignitor initially didn't work, because in my 1963 Dodge Dart, there was no ground wire inside the distributor. Once I hooked up a ground wire inside there, it fired right up.
I also learned from Pertronix the wiggle is okay under the rotor. He said that is what makes it so nice. The gap isn't all that important to be right on.
Whatever..... Thanks again for your help.
PostPosted: Tue May 29, 2007 5:28 am
The distributor should already be grounded and the plate mounting screw should give you the ground. Maybe not in your case. Didn't need an extra wire in my '63 Valiant.
Glad you got it working.
'63 Valiant V200 Convertible
225 Aluminum Block
PostPosted: Tue May 29, 2007 12:20 pm
Glad you got it running. Ours runs smooth all the way to 6000rpm, going to push it 6500 next weekend. Talk to you later Don
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
Users browsing this forum: Bing [Bot], Google [Bot] and 25 guests
