It is currently Wed Jun 17, 2026 12:43 am
PostPosted: Tue May 29, 2007 6:05 pm
Have a shot at a set of 4 ralley rims and tires, semi-local guy. Wants $75. for 4 rims and 4 tires. Said they came off a 67 sattelite and are 14's. The question is, if they're stock from the satelite, will they fit on a '74 Duster with Disc/Drum. I guess I'm trying to find out how deep the dish should be to clear the calipers. Any help? Need to decide quick. The price is great, but I don't need more parts laying around.
If it ain't broke, you didn't have fun playin' with it.
'74 Duster
'74 Valiant
PostPosted: Tue May 29, 2007 6:53 pm
Rallyes did not come out until 1970 in both SBP and LBP so they are not stock to the 67 Satellite. They should fit your Dart and clear the discs. Did a 73-76 disc swap on a 70 Dart and used LBP Rallyes and they fit fine. Hopefully the ones you are considering also have the center caps and trim rings.
PostPosted: Thu May 31, 2007 9:10 pm
Got the rims and tires. Rubber was newish, rims in good shape with a top coat of black spray on them. No center caps or trim rings, but I figured the price was right. Cleared the front calipers, but just barely. Thanks
'74 Duster
'74 Valiant
