It is currently Sat Jun 13, 2026 7:32 am
Post new topic  Reply to topic  [ 40 posts ]  Go to page 1 2 3 Next
 Post subject: Baaad noise!
PostPosted: Sun May 20, 2007 9:56 am
I was passing someone on the way home yesterday, I was in 2nd gear, fairly high rpm and I hear a sound that is best described as a vibrating squeal. I go home and shut it off. I start the car up this morning, runs fine, no odd sounds until I give it some throttle, then I can hear the odd knock as I flutter the throttle. The knock is not always there, only when I give it some gas. As I increase the throttle, the knock turns into that vibrating squeal, hammering may better describe the vibrating, this noise is not all the time, just at a higher rpm. At idle the car sounds normal. I dont know what the problem is, but would appreciate the help. Thanks.
Excuse me, does this smell like chloroform to you?
PostPosted: Sun May 20, 2007 10:54 am
Contributor
Just a guess, but the noise sounds like spun rod bearing.
PostPosted: Sun May 20, 2007 10:58 am
Just another guess for a spun rod bearing....
PostPosted: Sun May 20, 2007 11:04 am
What model and year are we working on?
PostPosted: Sun May 20, 2007 11:38 am
The car is 72 dart, 225 engine, 904 trans. Could it be a loose torque converter? I dont see or feel a vibration. Motor needs to be pulled, huh?
PostPosted: Sun May 20, 2007 12:00 pm
I would check the converter bolts before I pulled the motor. It's happened to me twice now.
PostPosted: Sun May 20, 2007 12:10 pm
I've seen where the converter bolts were still connected to the lugs, but the welds holding the lugs to the converter had broken, so look closely....
PostPosted: Sun May 20, 2007 12:41 pm
Long shot, but pull the fan belt. Could be a water pump or alternator. :shock:
PostPosted: Sun May 20, 2007 1:05 pm
I did pull the fan belt off. I was hoping that would be the problem. Nay.
PostPosted: Mon May 21, 2007 4:27 pm
SSRN National Champion
I have had flex plate bolts back out three times. Once on the 340 in my Barracuda and twice in my race car. Solid motor mounts tend to cause vibrations. All three times it sounded like a rod knock. I have not heard no squill or shrill noise. I doubt that the flexplate tabs have broke on the converter I tore a flex plate in two and the tabs and bolts were fine on the converter. My flex plate looked like a 8 inch circular saw blade. Thanks Ron Parker :D
Jaggers Fabircation Slanted Attitude Dart
PostPosted: Mon May 21, 2007 6:22 pm
Thanks for feedback, I will check the flexplate/torque converter. If it is a spun rod bearing, whats the best way to go? Replace all rod bearings? The whole bottom end?
PostPosted: Mon May 21, 2007 6:58 pm
Total rebuild would be my answer. Thanks Ron Parker :D
Jaggers Fabrication Slanted Attitude Dart
PostPosted: Mon May 21, 2007 7:22 pm
If it is sqealing you have already burnt the crank. If it is a low mileage short block I would roll the dice and put a crank kit in it. If it has miles, total rebuild is the way to go. :shock:
PostPosted: Wed May 30, 2007 5:45 pm
Well it is not a rod bearing, I pulled all of them. They all look brand new. I suppose its time to pull the main bearings? What is the chance they would spin?
PostPosted: Wed May 30, 2007 6:41 pm
50-50. Either it did or it didn't. :shock:
Users browsing this forum: Amazon [Bot], Bing [Bot], Rick Covalt and 5 guests
