It is currently Fri Jun 19, 2026 1:58 am
PostPosted: Tue May 29, 2007 2:24 pm
Try as I may to get the name of the part from my FSM, I've thus far struck out. Immediately below the point on the steering colum (automatic), there is a piece that surrounds the steering column and passes underneath the dash. Mine is missing....whatever it is called. Any help would be appreciated. If you would happen to have a green one in your garage that you aren't in need of, I would like to discuss that with you too.
Thanks.
 Post subject: column
PostPosted: Wed May 30, 2007 11:26 am
I've a couple of columns left over from the TMC giveaway cars - could you remind me what year you need and I'll look to see what I've got left over.
PostPosted: Wed May 30, 2007 8:50 pm
Do you need the metal colum support, or the smaller piece that covers the wires. Either way, I parted a 71 Dart and I have both pieces if they will work for your car. They should work for 67-76 A bodys. PM me if you want'em.
There are 3 things that will live forever, cockroaches, Keith Richards, and Slant Six Dusters !!!
http://s4.photobucket.com/albums/y128/slantasaurus/
take a look around
 Post subject: Missing part
PostPosted: Thu May 31, 2007 8:23 am
I found what I needed this morning. Thanks again.
