It is currently Thu Jun 18, 2026 10:49 am
 Post subject: door parts
PostPosted: Fri Jun 01, 2007 8:22 pm
i rolled down the right rear window today and about 2/3s of the way down it just fell off took the door apart and found a blue plastic plug that holds the regulator to the window had fallen out. now
where do i get them. 2 tangs are broken off of it. and if not available what should i use.
dowl with a bolt through it washers and nuts on each end?
PostPosted: Sat Jun 02, 2007 10:15 am
Year One has them... here is a link:
http://www.yearone.com/serverfiles/fbsh ... .asp?cat=A
If you can't wait, you can use a nylon nut and bolt from a hardware store.
-Mac
PostPosted: Sat Jun 02, 2007 4:44 pm
i looked and couldnt find them.
if you find them post me a link or a name, dont know what they are called.
PostPosted: Sat Jun 02, 2007 6:09 pm
On the menu, on the left hand side, click on "body" then "Door window hardware." They are called "plastic window-to-regulator attaching rivet. I'm not sure, but wasn't DusterIdiot looking for these too?
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
 Post subject: Heh...
PostPosted: Sat Jun 02, 2007 6:46 pm
A long time back I was, I have now, 'salvaged' a set of them out of a few 'parts doors' I have.
(Shudder at the price Year One sells things at....)
PostPosted: Sat Jun 02, 2007 7:18 pm
Car Model: 1967 Dodge Dart GT
are they removable? wondering with your quotes on salvaged, DI...if they are, would ones from a 73 work? i could hook you up again cheap
PostPosted: Sat Jun 02, 2007 8:09 pm
might not be worth it, they are 3.40 each thats not bad. rather new anyway
thanks thou.
dario
PostPosted: Sat Jun 02, 2007 8:14 pm
At $3.40 I would just buy the new ones. I might be able to get them through CR Laurence but I doubt they would be much less if they're even available.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Jun 02, 2007 8:17 pm
expensive... you were right the shipping is 7 bucks.
PostPosted: Sat Jun 02, 2007 8:27 pm
CR Laurence has a substitute product which consists of a plastic insert and a metal screw. This is what a typical glass shop would use but don't look for any relief on the price. My cost is $16 and change; the selling price would typically be about twice that. If that's the part you need, Year One's price is a bargain even with the shipping.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
