It is currently Thu Jun 18, 2026 5:51 am
 Post subject: evil vacuum leak
PostPosted: Sat Jun 02, 2007 7:58 am
Hello
I have a Holley 390 that I have been running on a 225 slant six with an Offenhauser manifold.
There is a persistent vacuum leak that seems to come from the gasket between the manifold and the carburetor.
When ever I change the gasket the leak stops for about an hour and then starts again.
This leak is on the inside edge of the gasket and causes a very loud whistle sound. If I spray some carburetor cleaner in the mouth the the carb the whistle will stop for a while then come back.
I am wondering, would a rebuild stop this?
Could this leak be due to something being warped?
Am I just using the wrong type of gasket?
Thanks
PostPosted: Sat Jun 02, 2007 11:15 am
Are you sure it is not between the carb mounting plate and manifold? I have had the plates leak and do the same thing.
I always seal the plate straight to the manifold with silicone.
What type of carb mounting gasket are you using? I have always used the gray paper ones and not had any problems, even when I re-use them 10 times. :shock:
PostPosted: Sat Jun 02, 2007 6:19 pm
Hi
Thanks, I think that the problem is that since I put a so called "dropped bottom" air cleaner on that too much heat is being trapped and that the gasoline is actually boiling!!!
The the whistling sound. I am going to try to put on an insulating gasket and a regular air cleaner.
PostPosted: Sat Jun 02, 2007 6:54 pm
The noise could even just be the throttle plates. When it is making the noise can you spray carb cleaner at the base & detect the leak. Or is it just noise.
jess
PostPosted: Sat Jun 02, 2007 10:05 pm
Hey
I tried my idea of using the non dropped bottom air cleaner and that did the trick.
I also put on some special insulating gasket from Mr. Gasket and that may have helped as well.
