It is currently Tue Jun 16, 2026 11:12 am
 Post subject: Will 400mm fit 4"?
PostPosted: Mon Jun 04, 2007 10:03 am
I know 400mm is not exactly 4" but has anyone ever tried a 400mm wheel on a 4" Valiant bolt circle? I've seen them advertised as either or but I would like to know. Thank You wise ones.
PostPosted: Mon Jun 04, 2007 10:19 am
400mm = 15.748"
Most A-Bodies don't even have wheels big enough to clear that bolt circle. :D
Did you mean 100mm? That is a common FWD bolt circle, and is 3.937".
No they wont work. I put a couple on my Valiant when I first got it because I didn't have any SBP wheels with tires that would hold air and I just wanted to roll the thing around. They worked ok (other than rubbing the springs because of the offset) but there's no way it would have been safe on the road.
It's a definite NO-GO.
'15 Chrysler 200S V6
PostPosted: Mon Jun 04, 2007 11:37 am
Nino, use the search engine on this topic... several people(including myself) have asked the same question
PostPosted: Tue Jun 05, 2007 5:47 am
You mean 100 mm. wheel bolt spacing. 25.4 mm/inch. 4" bolt spacing = 101.6 mm.
Not close enough according to popular thinking here on the forum or most tire/wheel companies.
'63 Valiant V200 Convertible
225 Aluminum Block
PostPosted: Tue Jun 05, 2007 7:49 am
Yes I meant 100 mm. Too many 4's in my head i guess. Thanks for the feedback.
