It is currently Thu May 28, 2026 1:54 am
PostPosted: Sat Jun 09, 2007 4:01 pm
I have a 1979 Dodge D-100 225 with a 3speed manual trans. Is the disc 11inch, 23 spline, 1inch? Is this the standard size for pickups? Also, is a Borg&Beck pressure plate more desirable than the Raised Diaphragm type? THANKS.
PostPosted: Sun Jun 10, 2007 5:36 am
Thomas,
You can have a larger plate and flywheel if your bell is cast iron. Do you have a transmission parking brake or rear wheel cable park brake?
rock
64d100
