It is currently Fri May 15, 2026 5:49 am
 Post subject: Clutch size
PostPosted: Tue May 14, 2002 2:25 pm
Do the slants use the same 10 -1/2 inch- 23 spline clutch as the typical v8 mopars??
Demonboy71@yahoo.com
 Post subject: Re: Clutch size
PostPosted: Tue May 14, 2002 3:33 pm
: Do the slants use the same 10 -1/2 inch- 23
: spline clutch as the typical v8 mopars??
No, the stock SL6 flywheel takes up to 10 inches.
There is a special truck clutch that takes the V8 11 inch but that is overkill for a SL6
<A HREF="http://www.slantsix.org/articles/clutch/sl6-clutches.htm">http://www.slantsix.org/articles/clutch/sl6-clutches.htm</A>
