It is currently Tue Nov 24, 2026 5:00 pm
 Post subject: manifold adapter?
PostPosted: Fri Jun 15, 2007 10:32 am
Hi guys!
Im about to replace my old one barrel holley for a 40/40 dual barrel...
I need to know if its possible to adapt my manifold (one hole) to palce the new carb... is it possible, I mean without changing the original manifold?
Thanks!
Mopar or no Car!
PostPosted: Fri Jun 15, 2007 12:13 pm
If you search on here for such a thing, you will find that it is possible, but not recommended.
The Old Goat '83 D150 225-2
AKA Ice Titan
PostPosted: Fri Jun 15, 2007 1:04 pm
It is possible, but it is a bad idea. Much better to start with a manifold intended for a 2bbl carburetor.
PostPosted: Fri Jun 15, 2007 1:33 pm
Like trying to breathe through a straw.
Excuse me, does this smell like chloroform to you?
PostPosted: Fri Jun 15, 2007 2:44 pm
Why is it not recommended?
Does it lose power?? has someone done it with bad experience??
Thanks.
www.dodge-tech.com.ar/forum
Mopar or no Car!
PostPosted: Fri Jun 15, 2007 3:09 pm
The one barrel opening is too restrictive
PostPosted: Fri Jun 15, 2007 3:25 pm
Is it the bore of the single barrel opening on the manifold, or are the manifold runners themselves smaller than those of a Super Six manifold? If it's only the opening for the carb, them I would think that could be machined out, with new holes drilled for appropriately placed studs for a 40/40. But I'm only speaking in the sense of thinking that it could physically be done. I would expect starting with a Super Six intake manifold would still be far more feasable.
PostPosted: Fri Jun 15, 2007 3:31 pm
The bore in the manifold is the same size as the 1bbl carb.
With an adaptor the 2 bbls neck down to the 1bbl size, thus no gain.
Modifying the 1bbl manifold has been done (bet SSDan knows the link) for 2bbl carbs
 Post subject: huh?
PostPosted: Fri Jun 15, 2007 3:51 pm
If the runners are the same size, why not just hog out the manifold to the same size as the carb gasket? It would be easy to use the adapter as a guide, and don't people use carb spacers as a performance upgrade anyway?
I figured that people here would be into doing it themselves? Or maybe the 2 barrel manifold isn't that hard to find?
Kevin
madam im adam
PostPosted: Fri Jun 15, 2007 4:18 pm
Is this what you're trying to do?
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
The 2bbl intakes aren't hard to find in North America. Not sure what the situation is in Argentina. Here's an article (pdf) on how to grind & modify a 1bbl intake to accommodate a 2bbl carb, with parallel orientation (factory 2bbls were perpendicular).
PostPosted: Fri Jun 15, 2007 4:23 pm
It can be done but there isn't a lot of real estate to work with and a 40/40 is a sizable pair of bores. It would be tricky at best. Even the "Super Six" manifold will require an adapter. I would think it would be more feasable with a 4 bbl manifold such as a Clifford or Offy. You would then be able to turn the carb 90* for improved fuel/air distribution. It seems to me anyway, but I've never done it - maybe someone here has.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Jun 16, 2007 8:51 am
Here's my modified 1 bbl
Super Six Conversion Stromberg
PostPosted: Sun Jun 17, 2007 8:35 am
I've seen stock intakes modified to 4bbls! BTW what is a 40/40? 40mm?
PostPosted: Sun Jun 17, 2007 6:59 pm
That's what I took it to be; 2 barrels, 40 mm each. Tha'ts a big carb.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 8 guests
