It is currently Mon Jun 15, 2026 1:14 pm
 Post subject: New engine /old manifold
PostPosted: Fri Jun 15, 2007 11:45 am
I have a 75 or 76 /6 and an earlier super-six manifold. I notice there is an extra manifold stud and opening at the back of the cylinder head manifold mounting surface. What is that and do I need to cover it/ bolt on some new part?
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Fri Jun 15, 2007 6:00 pm
The opening is about an inch in diameter. :?:
PostPosted: Fri Jun 15, 2007 6:46 pm
pipe plug
PostPosted: Fri Jun 15, 2007 8:46 pm
Car Model: 1963 Plymouth Valiant
That sounds like the opening for the air injection passages. You can probably tap it and put a pipe plug in it, but I made a block-off plate and bolted that over it instead, with a stock gasket. We'll see how well that approach works in a few months. I imagine plenty of folks have done it that way before, though.
PostPosted: Fri Jun 15, 2007 10:11 pm
That's the air injection port you're seeing. There's a factory blockoff plate available for it, P/N 3751 249, and gasket 4275 834 (though the gasket comes with any decent-quality manifold gasket set).
PostPosted: Sat Jun 16, 2007 4:55 am
I just used a small "freeze out" plug, but I have no back pressure. I am running open headers.
