It is currently Sun Nov 22, 2026 7:23 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
 Post subject: What at where, when...
PostPosted: Sat Jun 16, 2007 12:06 am
at idle should i be shooting for as high as possible or?
If you have 30 at just above idle and things are fine, that's ok....what do you get when you run the tach up to 2800 rpm?
PostPosted: Sat Jun 16, 2007 7:00 am
Car Model: 1967 Dodge Dart GT
my tach shocks me and doesnt work really :lol: dads got a multimeter with one, so ill look for that today, thanks
 Post subject: distributor advance
PostPosted: Sat Jun 16, 2007 5:03 pm
hey how do i tell what vac advance i have. i seen the stamp on the arm when i installed it. wondering what i bought. i got it off ebay.
is there any place on this forum or elsewhere for that info? i did some searchs but i'm not sure what to search.
 Post subject: Advance?
PostPosted: Sat Jun 16, 2007 5:24 pm
Anybody know where you can get a 15 or 16R vacuum advance?
THe highest I can find is a 11R advance.
If they still exist, where? and what is the part number?
Thanks
PostPosted: Sat Jun 16, 2007 7:40 pm
You can lengthen the slot in the arm that limits the travel in and out of the pot, with carefull work from a Dremel tool and a cut off disk, and make it any amount you want. Measure the slot, and do some match to figure a proportional amount to lengthen it. Simply slice a little metal out of the arm to lengthen the narrow part a MM or two, what ever the math tells you.
Sam
PostPosted: Sat Jun 16, 2007 7:53 pm
what is the formula to determine how much to cut out? thanks
PostPosted: Sat Jun 16, 2007 7:58 pm
If L1 is the current length and A1 is the current advance let L2 be the new length needed and A2 the desired advance then the formula will be:
L2 = L1 X A2 / A1, assuming a linear relationship.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Jun 16, 2007 8:22 pm
thanks!
 Post subject: Tach
PostPosted: Fri Jun 29, 2007 2:49 pm
That tach deal concerns me. Most I've hooked up have had the following wires. Black - earth/ground, Red - positive/hot wire, White - dash lights, Green - trigger wire hooks to neg side of coil.
Hope that helps.
From Mopars to classic Minis and back to Mopars in 19 years flat!
Will work for roast chicken crisps!!
Users browsing this forum: Bing [Bot] and 6 guests
