It is currently Wed Nov 25, 2026 5:07 am
 Post subject: Master Cylinder
PostPosted: Thu Jun 21, 2007 5:14 pm
My drum brake master cylinder is leaking. I plan on upgrading to discs in the future. Will a disc brake mc work with my drums so I don't have to buy 2 new master cylinders?
PostPosted: Thu Jun 21, 2007 5:18 pm
Yup no problem.
PostPosted: Thu Jun 21, 2007 6:06 pm
That's what I thought, just wanted to double check.
PostPosted: Fri Jun 22, 2007 9:27 am
Car Model: 1963 Plymouth Valiant
Hey Dan, not trying to be contrary, but are you sure?
iirc, it depends on what wheel cylinders you are using... the earlier ones needed a residual pressure valve (in the MC), whereas the newer wheel cylinders and 'problem solver' wheel cylinders had an expander built into the wheel cylinder.
Or am I just confused and the residual pressure is handled by the drum brake combo valve?
PostPosted: Fri Jun 22, 2007 9:41 am
RP valves went away when wheel cylinder seals were revised in '73. It is highly, highly, highly unlikely there are any old-style wheel cylinder seals are still in the current parts market.
PostPosted: Fri Jun 22, 2007 9:42 am
My car is a 73 and I when I got it, it had a disc brake mc. It leaked but seemed to work fine.
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
