It is currently Sun Oct 25, 2026 1:08 am
 Post subject: what size is this bolt?
PostPosted: Wed May 22, 2002 12:20 pm
The bolt that goes from the alternator bracket into the head on my '63 Valiant seems to have disappeared. The car is making a terrible squeak, does anyone know what size this bolt is so I can get a replacement?
Thanks!
rebeccanovak@yahoo.com
PostPosted: Wed May 22, 2002 12:52 pm
: The bolt that goes from the alternator bracket
: into the head on my '63 Valiant seems to
: have disappeared. The car is making a
: terrible squeak, does anyone know what size
: this bolt is so I can get a replacement?
: Thanks!
3/8 - 16 unc, 9/16 wrench hex head, about 1/2 to 5/8 long (threaded section)
PostPosted: Thu May 23, 2002 9:44 am
What size is the Crank bolt? Would be nice to have that pull the ballencer back on rather then use a hammer again...
Thanks!
PS: The mopar bushing kit is 22bux...But my local speed shop has Chevy ones that a few bux...I hear they are the same.
: 3/8 - 16 unc, 9/16 wrench hex head, about 1/2
: to 5/8 long (threaded section)
: DD
cralt@optonline.net
PostPosted: Fri May 24, 2002 9:50 am
Thanks for the information, nothing quite like the relief of fixing a hideous noise in the car for 32 cents :)
PostPosted: Fri May 24, 2002 10:27 am
: What size is the Crank bolt? Would be nice to
: have that pull the ballencer back on rather
: then use a hammer again...
: Thanks!
: PS: The mopar bushing kit is 22bux...But my
: local speed shop has Chevy ones that a few
: bux...I hear they are the same.
CrAlt,
The crank bolt is 3/4 fine thread X 1.5" long. You will likely need a longer one (2" or more)than that to install a balancer though.
You gonna make any Slant races this year?
Cheers,
PostPosted: Fri May 24, 2002 7:49 pm
: have that pull the balancer back on rather
I use a 5" long piece of 3/4 - 16 unf threaded stock and a large nut / washer. With this I can thread-in the stud under no load then wrench down the nut to push-on the damper. (this keeps you from wearing-out the crank snout threads)I use the washer in between the nut & damper face and coat it with anti-seize to cut down on the friction.
These work but they are a little longer so I cut them in half (lathe work) so I get a "2 bushings for 1" deal!
Users browsing this forum: Google [Bot] and 17 guests
