It is currently Sun Nov 22, 2026 9:14 pm
Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3
 Post subject: got it done
PostPosted: Wed Jun 27, 2007 3:28 pm
Ok,
i got just about everything installed, i put the original choke control back in (for now) and it works again! Also adjusted the idle down to 900 rpm's. I just have to get the correct breathers and hook up the cannister (just need to make a trip to the parts store). Now, on to the next issue, what causes oil smoke to come out of the valve cover when the car is running? Also, the valve train seems a bit loud (ticky)
PostPosted: Wed Jun 27, 2007 3:53 pm
Smoke out of valve cover = Check to make sure your PCV system is working correctly.
PostPosted: Wed Jun 27, 2007 4:40 pm
smoke out the valve cover.... is that because of the cheapie valve cover?
(no baffles) Did it smoke like that before with the old cover?
PostPosted: Wed Jun 27, 2007 7:13 pm
I honestly did not notice any smoke, but that was with the stock cover and pcv in-tact. The smoke is coming out of where the pcv is supposed to go, i do not have the proper breather yet. But, i figured it was not supposed to smoke like that!. Honestly, the car ran and drove pretty well when i got it, it was a one owner, old lady car. I only started doing replacements because all the hoses were so dried up, etc so i figured why not replace everything i could get at! The hesitation in accelleration is gone now with the new carb and the choke installed. Does it really matter that much about the cheap valve cover, i mean, if it is going to be big deal i would rather clean and paint the original.
PostPosted: Wed Jun 27, 2007 7:41 pm
You'll get smoke out of the valve cover if the PCV system isn't intact and working. I've already put in my vote as to which valve cover to use, but the choice is yours! :-)
PostPosted: Wed Jun 27, 2007 8:13 pm
I'm curious why you think the Offy valve cover will work better given that it also lacks baffles. I don't question the higher quality of construction but I don't see how it is functionally any different unless I'm missing something.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Jun 28, 2007 8:15 am
I'm curious why you think I voted for the Offy valve cover! :twisted:
PostPosted: Thu Jun 28, 2007 11:15 am
Well after re-reading your post I can say that you did say the factory cover was the best so I guess technically that's your vote. The remark about the Offenhauser being better is what struck me and I found that curious in light of the lack of baffles in that one as well. On the other hand, I didn't say you voted for the Offy, only that you said it was better.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Google [Bot] and 10 guests
