It is currently Sun Nov 22, 2026 10:23 pm
PostPosted: Wed Jun 27, 2007 2:36 am
Hi i wondered if anyone can tell me the opening and closing order of the cylinder head(valve head?). Well in any case the head that sits on top of the cylinders with the valves in it. And if you know how much they should be tighten too when mounted back, would help much too. Oh and its a 225 from 67 if that matters in any way. Thanks in advance.
PostPosted: Wed Jun 27, 2007 3:39 am
this will help.
65ft/lbs. I tighten to 50 first,then finish to 65.
Rod
PostPosted: Wed Jun 27, 2007 1:13 pm
He needs the valve adjusting procedure, not the head tightening sequence.
The Old Goat '83 D150 225-2
AKA Ice Titan
PostPosted: Wed Jun 27, 2007 4:09 pm
hello,
well now he has both.
I read his post several times,and reckon he means to remove and refit
head. anyway,now he should be right.
so how is it going dodge 7619 ?
Rod
PostPosted: Wed Jun 27, 2007 6:35 pm
I think he's looking for the valve openning and closing sequence. Not sure why he would want it, but thats what it sounds like to me. Maybe to set cold valve lash with only turning the engine once?
PostPosted: Wed Jun 27, 2007 8:09 pm
that's easy, with a simmetrical engine, you draw an imaginary line in the middle. When one rocker arm is on the top intake travel, you set lash on both valves on the opposite cyl. (like in 1-6 2-5 3-4)
you can't set lash with only 1 turn of the crank since i turn of the crank equals only half turn on the cam, so on the first crank turn you lash 1 - 5 - 3 and in the second 6 . 2 . 4
hope to be clear...
Juan Ignacio Caino
PostPosted: Thu Jun 28, 2007 1:39 am
Thank you very much for the help. The thing I am going to do is to remove the old valve head and straighten it out, cause it probably is twisted. (Leaking coolant into the oil.) And put it back together.
Thanks for the valve adjusting proc too.
Usefull tips are also welcome cause I´m going to do this for the first time.
PostPosted: Thu Jun 28, 2007 2:20 am
smug. :D giggle. such humility. blah ! :twisted:
Rod :P
