It is currently Mon Nov 30, 2026 1:49 pm
 Post subject: parking brake trans seal
PostPosted: Mon Jun 25, 2007 4:12 pm
63 valiant wagon 170/pushbutton 3 spd, the seal that the parking brake cable enters in the rear of trans is leaking(gasket is split), is it readily available and if so where?
PostPosted: Sun Jul 01, 2007 9:29 am
I would try bulkparts.com They seem to have most everything and are inexpensive. I think they have a minumum purchase policy. You may just want to get an overhaul gasket and seal set, they are not that much.
PostPosted: Sun Jul 01, 2007 11:27 am
Suggest getting your early-Torqueflite seals and parts from Pat Blais, tflitepatty@verizon.net . Pat is very knowledgeable about these transmissions and can save you a lot of "oops, not quite the right part" or "oops, have nine out of the eleven parts I need" grief.
 Post subject: thanks for the leeds
PostPosted: Mon Jul 02, 2007 8:56 am
thanks to Anotherslant and slant six dan for your help!!! Will contact said people.
Users browsing this forum: Amazon [Bot] and 3 guests
