It is currently Mon Nov 30, 2026 12:04 pm
 Post subject: Daily Driver Rear Axle
PostPosted: Mon Jul 02, 2007 10:30 am
Hello
I got the parts from 73 Valiant replaced my front drums to disk and changed the rear axle for the big bolt pattern the rear is shorter then the front and the rear wheels set in 2 inches or more and make the front look like it’s on steroids my question is what other rear end can be used on A body cars that will have a better look so I don’t have to use spacers to fill in the gap.
PostPosted: Fri Jul 06, 2007 10:47 am
The Factory A-Body application using the LBP Disc produced a wider track in front, that is they way Mopar sold the 73-76 A-Body Disc Brake cars.
You can us a mid 60 B-Body rear, that would wides the track by 1 1/2 inches but tire clearance to the rear fenderwell will be tight.
