It is currently Mon Jun 15, 2026 11:02 pm
PostPosted: Wed Jul 04, 2007 4:32 am
Hi, this manifold I directly milled into the flange to mount the injectors.[http://moparmarketforum.com/phpBB/download.php?id=1844]
PostPosted: Wed Jul 04, 2007 6:24 am
I could not get this link to work. Maybe the address is typed wrong. Thanks for trying.
Sam
PostPosted: Wed Jul 04, 2007 6:26 am
Let's try this one.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
 Post subject: Efi
PostPosted: Mon Jul 16, 2007 7:16 pm
Where did the rail originate? your work or can just any joe walk in off the street and get one? Nice....
PostPosted: Mon Jul 16, 2007 9:36 pm
That looks quite nice. Do you have the rest of the system planned out? What ecu are you using? HOw are you plumbing your fuel from the tank and back?
Sam
PostPosted: Tue Jul 17, 2007 12:41 pm
8) Looks great!
PostPosted: Wed Jul 25, 2007 1:48 am
The fuel rail is 316l stainless steel 16mm x2mm wall.Turned/made up fittings on the lathe and TIG welded them on.Running a GM V6 holden ECU(V6 buick) and a modified points type distrubtor.Added a return line fitting to the OE tank sender unit 5/16.Ran the line next to the Chrysler OE line and up the bulk head by the steering box.
