It is currently Fri Jun 12, 2026 7:03 pm
 Post subject: 75 Dart noise in rear.
PostPosted: Sat Jun 01, 2002 11:21 am
I have a stock 75 dart I have noticed a noise, kind of a squeak in the rearend over the past few weeks. Today I was out on the highway and suddenly at road speed the car started to lose power and then pick back up, when I let off the gas there was a bad rumble in the rearend.
Any advise as to what to check first would be greatly appreciated.
I have checked the oil in the rearend and it is fine, but I don't know what to do next.
Thanks
James
jsbgraphics1@netzero.net
PostPosted: Sat Jun 01, 2002 5:17 pm
: I have a stock 75 dart I have noticed a noise,
: kind of a squeak in the rearend over the
: past few weeks. Today I was out on the
: highway and suddenly at road speed the car
: started to lose power and then pick back up,
: when I let off the gas there was a bad
: rumble in the rearend.
: Any advise as to what to check first would be
: greatly appreciated.
: I have checked the oil in the rearend and it is
: fine, but I don't know what to do next.
: Thanks
: James
Sounds like a bad wheel bearing to me.
mwhiteho@hotmail.com
PostPosted: Sun Jun 02, 2002 7:38 am
: Thanks
: James
Jack the car up and remove the drive shaft. Now you can inspect the u-joints and rotate the readend around by hand to be sure the problem is back there.
If the rearend seems tight or "crunchey", pull off the inspection cover and/or the axle shafts for a look, or just start looking for a replacement unit.
