It is currently Fri Nov 20, 2026 9:10 pm
 Post subject: Head seepage
PostPosted: Fri May 04, 2007 3:40 pm
Noticed that my intake runners have some oil seepage at the head. Its not alot but, there's more at the front one than towords the rear one.
I have also had some seepage on the other side. This has gone on since I had the truck (1982 225 auto). Tried different things but, heard that the head might need to be retorqued. Is this true and if so, do I need to put on a new head gasket?
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Fri May 04, 2007 3:58 pm
It just take some time and a valve cover gasket in order to retorque the head.
Warm the engine and test the head bolts to see how tight they are.
You will find that they will take a lot of force before the bolt "cracks loose and starts moving / gives you an accurate torque reading.
Search the messages for more details.
PostPosted: Fri May 04, 2007 4:56 pm
When you say crack loose, do you mean to back the bolt out a little then start to torque the bolt forward?
PostPosted: Fri May 04, 2007 5:09 pm
Me... I just tighten them more.
I used to go in the loosen direction to crack the bolt loose, then tighten but these days I have a better feel for how much overtorque it takes to get the bolt moving, so I just go tighter.
PostPosted: Fri May 04, 2007 7:23 pm
I have no feel on a torque wrench. Do I torque to specs or more?
PostPosted: Fri May 04, 2007 8:23 pm
I retorque to 70-75 ftlbs. on cast iron Slants.
PostPosted: Sat May 05, 2007 7:40 am
That's exactly what my head was doing. The bolt torques were ok so I pulled the head and had some work done. Just waiting for the weather to clear to get back on it.
The Old Goat '83 D150 225-2
AKA Ice Titan
PostPosted: Sat May 05, 2007 8:31 am
Was the head warped or something else?
PostPosted: Sat May 05, 2007 11:10 am
I pulled the head figuring I would replace the gasket. It was filthy from all the oil and 24 years of driving. So I got the head cleaned and resurfaced. I had them do a valve job with new valves. I didn't do a compression test before all this so I don't know if there's still a possibility of bad rings as has been suggested by some. I explained all this to my mechanic to see if he had any ideas. He thought the rings probably weren't the source of the oil. He suggested a PCV system clog. Unfortunately, I'm the only one who's seen the engine outside of pictures that are linked in my sig.
AKA Ice Titan
PostPosted: Sun May 13, 2007 1:01 pm
Do I loosen all the bolts and then retorque from the center out or loosen and retorque one at a time from the center out?
PostPosted: Mon May 14, 2007 9:12 am
Do them one at a time... work from the center, out.
PostPosted: Fri Jul 13, 2007 12:22 pm
It didn't stop the seepage so I guess need to get a new head gasket. What is recomended? Is Felpro or Rol good?
Users browsing this forum: Bing [Bot] and 8 guests
