It is currently Fri Jun 12, 2026 12:55 am
 Post subject: Transmission slips
PostPosted: Fri Jul 13, 2007 2:49 pm
My trans slips once in the morning after I warm my car up, it does'nt slip after that just once in the morning. Can anyone help me on this. Maybe the band s need tighting. It has plenty of trans fuid.
PostPosted: Fri Jul 13, 2007 4:24 pm
that is most likely because of bleed down inside the trans
(often caused by miner leaks in gaskets/seals in side);
but could also be a partly plugged filter under the pan.....
place the trans in N for 30seconds to 1 min before driving it,
this fills most of the cavitys inside and it should not slip when
cold after that.
If it has not had a filter change in a few years it might be
a good idea.
What color is fluid and does it smell burnt at all?
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
PostPosted: Fri Jul 13, 2007 8:31 pm
Yep, Jeffc has a good idea. In fact, if you shift from Park to Neutral first thing when you get in the car, then start it, then fasten your seatbelt and get ready to go, then release the parking brake, by that time you should be able to shift into Reverse or Drive and have no slippage. Fluid and filter change also a good idea if it's been a few years.
PostPosted: Sat Jul 14, 2007 5:17 am
Thanks I'll try this today and get a tran service
PostPosted: Tue Jul 17, 2007 4:58 pm
sounds like torque converter drainback. Once shifted out of Park, TC refills and all is well.
