It is currently Fri Nov 20, 2026 2:42 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Fri Jul 13, 2007 2:57 pm
SlantSixDan, I stand some what corrected :oops: Not enuf coffee this am but I have had 2 Dodge 318 in past years that behaved just like Jopapa's slant and the ballast was the culprit. Now maybe the starter was dragin all the juice from ign I don't know except they wouldn't even fart let alone start. My first one, mech listened to my tale of whoa and showed up with a new ballast, screwed it on and pluged it in and,ta da. Kept a spare ever since and used one again years later when symptom was the same an ta da. Go figure, worked for me and all cars/trucks seem to get a personality all their own, so who knows? :roll: I like your posts SSD, you got some good info, tks :)
PostPosted: Fri Jul 13, 2007 4:50 pm
Well, either the ECU or the coil had taken a dump. I did the HEI conversion today and t fired right up. I had to reset the timing and I went ahead and regapped to .045, and it runs beautifully now. Much better startups and smoother idling. Didn't knotice any real performance gain (then again I only drove it around the block), but hopefully this'll help me improve my mileage even more.
Now I just have to take the time to clean up my install when I get the chance.
I didn't measure any regular copy paper but I did measure a post-it note at between .003 and .004
Ah, well, there we are, then: A Post-It or piece of regular paper folded tightly in half to set the air gap if you haven't got the brass feeler gauge.
Folded post it note was very close to .008 and 20# copy paper is almost identical.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Jul 13, 2007 9:54 pm
Jopapa,
Did you use the same coil to fire it up?
If so, it sounds like the ballast resistor or ECU gave up the ghost and not the coil.
If you do buy a coil, get the MSD Blaster 2.
It made my rig perform allot better.
PostPosted: Sat Jul 14, 2007 6:23 pm
Jopapa,
I installed a Blaster 2 along with an Accel controller, so that's why I'm ont sure if it was the original coil or the ECU. I know it wasn't the resistor, because it wouldn't even give the initial "burp" of cylinders firing during cranking.
It definately runs great now. Now I just have to find out WTH is rattling and clunking in my suspension...
