It is currently Tue May 26, 2026 7:57 am
PostPosted: Sat Jul 14, 2007 5:49 pm
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0145031764
Could this be used to couple a slant to some industrial application? There's no hole for a clutch release fork.
 Post subject: High mounted starter
PostPosted: Sat Jul 14, 2007 6:37 pm
Car Model: 1965 2 Dr Sedan, Wagon, Barracuda and Convertible
It's got a high mounted starter and the bolt pattern doesn't look right. If it fits a slant maybe it a marine motor bell housing. Some of the marine setups ran the motor on its side. There is also the Clark Motor Home from the 60's that used a slant. Have your guys seen this?
http://tinyurl.com/2oe8wa
1965 Valiant 200 /6 2dr Sedan.
1965 Valiant 200 V8 4dr Wagon
1965 Barracuda /6
1965 Valiant Convertible V8
PostPosted: Sat Jul 14, 2007 7:26 pm
Which bolt pattern doesn't look right? The trans side? Looks to me like it was meant to drive a hydraulic pump.
Most marine stuff was cast iron. Many marine bellhousings also had motor mount provisions.
I know about the Clark Cortez and saw that thread.
PostPosted: Sat Jul 14, 2007 8:29 pm
I bet it runs some kind of pump. It's not anything I ever seen before.
1965 Barracuda /6
PostPosted: Sun Jul 15, 2007 7:37 pm
You know why it looks funny.....it's for a STANDRAD shift, not a standard shift.
This from a guy who types with 2 fingers... :roll:
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
PostPosted: Sun Jul 15, 2007 8:01 pm
That housing was on the Bag a couple months ago. I would guess it fits a pump or generator. :shock:
PostPosted: Sun Jul 15, 2007 8:45 pm
Generators usually support one end of the generator armature with the crankshaft and have a much more open end than this thing. This is true for my 1940s 1kW Wisconsin driven generator and the 750kW Cummins V12 driven gennys at work. I still think it's meant to drive a hydraulic pump. I asked the seller for casting numbers and if they had any idea what mounted to the bellhousing, but got no reply. I did just ask Saturday though.
PostPosted: Mon Jul 16, 2007 12:38 pm
The seller replied: "this is for an industrial application Thanks ron"
Some help huh?
PostPosted: Mon Jul 16, 2007 9:26 pm
I bet it is a pump bell, water pump that is....
a lot of slants were used to water fields.......
I don't see any place to put a clutch arm so it ether didn't have
a clutch or arm it was under the bell.
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
PostPosted: Thu Jul 19, 2007 6:48 pm
SSRN National Champion
could be a pump, a welder, or a aircraft tow, or a combine. or generator, I have even seen one used as a jet engine apu. Boat, Ferris Wheel ,Tilt a whirl, silo blower, Who knows. Thanks Ron Parker :D
I Think Bagel Used One For A Sugage Grinder At One Time.
