It is currently Wed Nov 18, 2026 3:59 am
PostPosted: Wed Jul 18, 2007 10:11 pm
Hi All,
While coming home from a little trip-in my 66 Dart (of course)-the slant stumbled a couple of times then died. Thankfully I was about 3/4 of a mile from my house and was able to coast all the way back to my driveway. Motor would crank fine but would not attempt to start. First suspect was fuel delivery. Pulled the air cleaner and hit the throttle. A nice stream of gas came from the pump. Next a visual check of electrical connections-everything looked good-so I pulled the distributor cap. Rotor was next and revealed the problem-the points looked like they had about a half inch gap.....
By this time it was late and my local auto parts stores were closed. The next morning I go to pick up a new set of points. And -yes-the local guys still keep 'em in stock. Counter guy asks me if I want the cheap set or the more expensive ones. I counter back and ask him what the difference is between the two other than price. The cheap set is made in China. The pricier set is made in the USA. It turns out the set that failed in my Dart was the China made set I had unknowingly purchased-they lasted less than 8000 miles. The follower (as shown in the pics-please click on to enlarge) had broken off the cheap set. The cheap set only has two rivets that hold the follower. The Standard made in USA set has four rivets that hold it together and appears to be of much better construction.
Distributor as pulled-note the "follower" laying to the side
Another view of the cheap set
This is the Standard set-note the better construction.
So (obviously) I bought the Standard made in the good old USA set. Pulled the distributor, installed and gapped the new point set. Set distributor back in its prior position and hit the key. It fired up immediately. Set the timing and drove to my folks house, about 8 miles, and it never missed a beat.
The lesson in all of this: Be very careful what you buy! I would not have purchased the first set if I had known of the poor quality. Always ask before you buy. A couple of bucks saved now could spell disaster down the road. Well I've typed enough-Hope someone else finds this helpful!
Todd
1968 Valiant V200-a Work in Progress
PostPosted: Wed Jul 18, 2007 10:25 pm
just a glimpse of the future. :roll:
PostPosted: Thu Jul 19, 2007 1:45 am
Standard is all I use/have ever used for ignition products. All my dad and his dad used on their vehicals also. A case on point of you get what you pay for!
PostPosted: Thu Jul 19, 2007 8:06 am
Dude, why didn't you just spring for the extra and get a Pertronix? Then you'd never had to deal with points again!
PostPosted: Thu Jul 19, 2007 10:22 am
Good Point 69A100-Some sort of electronic ignition is on my "want" list.
Ahead of EI are a later model brake master cylinder upgrade and a voltage regulator / alternator upgrade. All in time as funds allow.
Todd
