It is currently Tue Dec 23, 2025 6:13 am
PostPosted: Thu Jul 19, 2007 3:24 pm
what is the correct mopar part # for a small high torque starter. or is it just the 318/360 starter??
PostPosted: Thu Jul 19, 2007 3:28 pm
'89-'01 3.9 V6 plus 5.2/5.9 V8 starter.
PostPosted: Thu Jul 19, 2007 3:36 pm
thanks Dan!!!!
PostPosted: Fri Jul 20, 2007 12:55 am
would it work on a 73 duster? i want to drop some weight off the motor and read some were that i can change the starter but i'm not sure what will fit.
PostPosted: Fri Jul 20, 2007 1:44 am
Yes, one will work on your '73 engine, or any slant engine for that matter. I've read of some guys having issues with later units, maybe thats only on V8's though. Dan?
PostPosted: Fri Jul 20, 2007 7:01 am
The '02+ units have no nosecone, so alignment and bushing wear can be a problem. Stick to the '89-'01 units and you'll be fine. See this post for info on the different terminal adaptors available in case you need extra clearance. And be advised that the "100% new!" starters you can buy locally at parts stores or off eBay are Chinese counterfeits, not the real deal.
