It is currently Mon May 11, 2026 6:51 pm
 Post subject: Tow Bars
PostPosted: Mon Jul 23, 2007 11:24 pm
I'm hot rodding a 65 coronet ( slanted version of course) on a very limited budget. Can't wait much longer to get the old gal to the strip and would like to make it a once a month or so deal.
I would like to take the exhaust system and remove all the extra pounds
off the car and get to the track legally.... so I purchased the least expensive means of transport...a tow bar. There was no research on the subject... I'm a make it work kind of guy. After all I see people dragging cars down the highway with bars all the time.
:oops: I did not know that it was next to impossible to make a sharp turn without getting out and turning the wheel on the towed car first.....there are rubber marks around every corner near my home as evidence of my practice sessions. I'm lucky I did'nt roll a tire off the wheel on the first few turns.
If anyone has any operationl hints on how to best use this thing I would appreciate it. How about tire pressure? does a 2 inch rake on the Dodge hurt anthing? ect...ect...ect
I have'nt felt this awkward since first learning to back a trailer years ago.
Thanks
Trysix/David
65 CORONET 4DR
SAME CAR BUT I REINVENTED MYSELF
PostPosted: Tue Jul 24, 2007 12:16 am
I've never had a problem with tow bars..........
Just make sure the steering isn't locked (and you can't back up).
The front wheels should steer themselves into the turn, and the towed car will follow you.
You just need to be moving, and don't turn too quick.
PostPosted: Tue Jul 24, 2007 5:57 am
If the car has power steering, it will be harder to follow. Also you must make sure the front end alignment is correct. If the car has a rake, the alignment is probably wrong.
PostPosted: Tue Jul 24, 2007 2:20 pm
If the alignment is correct, it will tow foward with no problems, but backing up will flip the front wheels to the side.
Try backing up with what you have. If it backs up better than it goes forward, have the alignment checked.
Slant Cecil
 Post subject: Maybe More Practice ?
PostPosted: Tue Jul 24, 2007 8:44 pm
Thanks for the input,
The aglianment is good ( no abnormal tire wear)
and there is on pulling , slack, or shake. It's manuel steering.
The only person that I know who has used one said my problem with sharp turns is the nature of the beast....but it sounds like you guys have had a better experience using a bar.
I plan on cranking up the torsion bars to level out the car and I'll try again tomorrow.
Still Trying Six
David
65 CORONET 4DR
 Post subject: Re: More Practice
PostPosted: Tue Jul 24, 2007 8:49 pm
Still Trying Six
David
That does not mean the alignment is correct. Wrong caster will not show up as tire wear, but will cause the car to not follow, corectly.
PostPosted: Tue Jul 24, 2007 9:56 pm
Good point...I don't know a lot about alignment but as I remember caster is the tlit forward or backward of the spindle. If I'm correct, this could be caused by the back of my car being higher then the front..? MMMMMM
David
65 CORONET 4DR
PostPosted: Wed Jul 25, 2007 6:57 am
David
Now you got it> :D
PostPosted: Wed Jul 25, 2007 9:44 pm
Isn't the castor with manual steering almost zero or negative? I think this has to be it. I had the same problem towing a car without an engine in it once. A friend and I waited until about 12 am and took it real slow on surface streets, turning real wide.
We towed another friends charger about 400 miles with the same pickup and tow bar, no trouble at all, it must be the alignment.
PostPosted: Thu Jul 26, 2007 11:40 am
I dunno whether alignment has that much to do with it more so weight distribution. I once towed a 63 Dodge Town Panel with a tow bar and wound up having to have my cousin (the owner) ride in it and steer every time we had to turn, yet when I brought my parts '77 volare back from Louisville to Chicago (ebay find) I couldnt even tell I was towing anything.
As I remember the 63 had no motor/trans underhood but was way full in back. the volare was all together, running driving rustbucket, trunk empty except for spare tire and the driveshaft which I pulled so as not to tear up the trans(no rear pump, so no lube)
PostPosted: Fri Jul 27, 2007 9:12 am
Not having an engine in, with the front end up negates the positive castor on every front end I have seen.
The weight distribution will matter if it is to the rear and you try to brake hard. The rear of the towed vehicle might try to come around, it goes one way while pushing the tow vehicles rear the other, you could actually jackknife if not careful.
PostPosted: Sun Jul 29, 2007 4:44 pm
I corrected the rake (raised the front) and the problem got worse.
I could'nt even make a slow wide turn. Next stop is the front-end shop.
Trysix
65 CORONET 4DR
 Post subject: tow bar
PostPosted: Tue Jul 31, 2007 7:27 pm
Positive caster will help the car tow better yet it maybe harder for you to turn while driving, Just a trade off.Yea,, this was all we had in the 60's and 70's. You were SOMEBODY if you had a trailer back then. Gravel on the roads only make the problem worse. Back then every racer had "Tag-alongs" and we let them ride in the car to help the problem. May not be legal anymore, don't want to be too safe yaknow,,,,,,....
PostPosted: Tue Aug 07, 2007 6:30 pm
I had the front end aligned yesterday. I can now make slow-wide-turns but sharp turns require getting out and turning the steering wheel.
I'm now trying to get my nerve up to make the approx. 20 mile trip to the strip.
Trysix
65 CORONET 4DR
 Post subject: Green car Yellow tow
PostPosted: Sat Sep 01, 2007 11:16 pm
I still haven't towed the thing yet but I did drive it to the strip today.I made a few runs with a full tank, spare tire and jack, and my little (made in China) emergency tool kit.
For e.t. go to Virtual Drag strip.
Trysix
65 CORONET 4DR
