It is currently Sun Nov 29, 2026 7:22 pm
 Post subject: Rear Trans. Mount?
PostPosted: Tue Jul 24, 2007 12:04 am
I'm looking for a rear trans. mount for my '64 A-100 van. Mine's a little sloppy and I'm wondering if it caused a pretty new rear trans. seal to start leaking real bad. I'm told new mounts aren't avail for a '64.
Any suggestions?
Thanks,
Tom
PostPosted: Tue Jul 24, 2007 8:25 am
Here is the OEM part number from my truck 66 parts book
2508 321
Just maybe it will cross to cars, but may not.
It is listed as a A100 only item.......
A good used one may be your only option.
Might try http://wildcatmopars.com/
they have a few A100's to part out.
Might check ebay as there are some pretty odd things that
show up from time to time.
http://engine-swaps.com/frames/frame_Homepage.html
this outfit also has some mounts that no one else has.
Also might drop into one of the truck sites and post a parts want.
http://www.sweptline.org/
http://pub36.bravenet.com/forum/show.ph ... 3079965801
Most rear seal issues I have seen have more to do with
driveline balance issues and small burrs on the slip yoke,
but a bad mount could cause it if the mount were very sloppy.
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
 Post subject: Re: Rear Trans. Mount?
PostPosted: Tue Jul 24, 2007 11:28 am
Any suggestions?
Thanks,
Tom
I may have found one NOS mount number 2508321, for you. I will send you a PM, with the contact info, since there is only one.
PostPosted: Tue Jul 24, 2007 1:43 pm
:shock: good find Charrlie_S ---------
there you go, that is why I took the time to look up that
number, never know whats out there.
Just be sure to compare it to yours, if possable, before you
buy :D
62 D100 225 3sp lwb
Old iron or no iron
PostPosted: Wed Jul 25, 2007 7:41 am
Thanks for the help guys, I'll let you know if it's the same mount.
Tom
Users browsing this forum: Rick Covalt and 2 guests
