It is currently Wed Nov 18, 2026 5:19 am
PostPosted: Fri Jul 27, 2007 10:42 am
I got a 270 in my new motor. It runs well but the timing curve is off. 1000-2000 RPMs is a little sluggish then feels like I got a turbo and the boost kicked in between 2000-4000 RPM. 2bbl carb, dutra duals, and some porting of the head. this is infront of a t5 and 3.91's. Any other Ersons running?
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Fri Jul 27, 2007 11:20 am
I believe that cam has a 2000 -5000rpm range.
PostPosted: Fri Jul 27, 2007 11:27 am
What is the static compression ratio of your engine?
PostPosted: Fri Jul 27, 2007 12:43 pm
I figured it out a while ago. I cant remember exactly but its around 9-1
PostPosted: Fri Jul 27, 2007 9:13 pm
Can you run a compression test and give us cranking compression in psi?
