It is currently Wed Nov 18, 2026 5:54 am
 Post subject: bent push rod, replacing
PostPosted: Fri Jul 27, 2007 6:56 pm
Turns out that #4 exhaust push rod was off it's rocker and in harms way. I need a replacement. Does anyone have a suggestion as to where to get one?
thanx.
PostPosted: Fri Jul 27, 2007 8:25 pm
You should be able to get a pushrod at any parts store. They may have to order it though. Autozone used to have them for about $5.
PostPosted: Fri Jul 27, 2007 9:26 pm
Send me a PM with your address, and I can send you one for the postage.
 Post subject: How did it happen?
PostPosted: Sat Jul 28, 2007 1:27 pm
Thank you for the kind offer.
I have already requested one from me local NAPA store, they say it will be here by Tuesday and the cost is reasonable.
Could a stuck valve cause this rod to bend? And if so what would be the remedy?
Thanx again.
Users browsing this forum: DuckDuckGo [Bot] and 4 guests
