It is currently Fri Nov 20, 2026 1:05 am
 Post subject: Cam bearing tool
PostPosted: Sun Jul 29, 2007 4:47 am
Hello everyone,
I did a search about removing/installing the cam bearing as I'm going to d o it in a shorwhile, only waiting for my block to be cleaned...
So I found this thread : http://slantsix.org/forum/viewtopic.php ... aring+tool
Does anyone have pictures of these tools? I can't seem to picture what it can look like...
Marc
PostPosted: Sun Jul 29, 2007 5:59 am
Marc,
I have on of these Tools, but no picture of it yet,
Go to www.summitracing.com
They should have a picture there (search For Cam installation Tool) - I bought A cam Baring tool from them last year, and It was a bit expensive, but it works great, and Pays for itself in 2 uses. I got the universal one, so it works with all motors- It's also great for Transmission tailshaft Bushings etc.
PostPosted: Sun Jul 29, 2007 8:56 pm
The Snap-On guy will sell you a Lisle Cam Bearing tool or you can buy it Lisle branded. Northern Auto Parts has it for $143.
http://www.northernautoparts.com/Produc ... delId=1974
PostPosted: Sun Jul 29, 2007 11:52 pm
Ok so these tools are expanding units? I don't really understand how can it make a bearing come/go while it's expanding it...? It should be interfering with the journal?
Anyhow, can I just machine on a lathe a piece that's just a bit smaller than the bearing and make it go in and out that way?
Thanks for your help
Marc
PostPosted: Mon Jul 30, 2007 1:17 pm
The expanding part that fits in the bearing has a shoulder that drives the bearing into the block. You could make something on the lathe, but you'll end up making 4 somethings as all 4 bearings are of slightly different size.
PostPosted: Mon Jul 30, 2007 2:26 pm
I have some cam bearing installation tools that are made out of old cam shafts.
 Post subject: makes sense
PostPosted: Mon Jul 30, 2007 5:47 pm
[You could make something on the lathe, but you'll end up making 4 somethings as all 4 bearings are of slightly different size.]
I never thought about it before but making each bearing a little bigger makes perfect sense. I wonder long it took the engine builders to think of this. (Not very long I'm sure)[/quote]
Users browsing this forum: Google [Bot] and 144 guests
