It is currently Fri Jun 05, 2026 7:08 pm
PostPosted: Sun Jul 29, 2007 12:30 am
Just wondering what parts I might need to make the switch and if anyone has done this. Any major gains or losses from the conversion.
As far as i know, I need a new steering box, steering coloum and a convertor/adaptor. The box was an easy find but the coloum is proving a little more dificult, and I'm not sure about the adaptor. Any info at this point would be helpful.
Thanks
PostPosted: Sun Jul 29, 2007 5:49 am
Flaming River has an adapter shaft that will do the job for you; no need to change the column.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Jul 29, 2007 5:53 am
Yes What Dakight Said, also you can get these adapeter From Steer n' Gear and also mancini Racing. They work Fine.
Shouldnt this thread be in the Suspension / Brakes Section?
PostPosted: Sun Jul 29, 2007 9:22 am
So all you'd need is the manual gearbox and the adapter? That just seems too simple to be true.
And yeah I agree, this should be in the S&B section...
PostPosted: Sun Jul 29, 2007 11:11 am
Thanks for the links, sorry for posting in the wrong section...still new to this forum. But everything has been very useful.
PostPosted: Sun Jul 29, 2007 9:51 pm
So when swithing, is it just a swap of the power steering pump for the manual steering box?
And the adaptor just fits onto the steering coloum?
PostPosted: Sun Jul 29, 2007 10:19 pm
This is the kit I used - the u-joint part fits on the steering box, the shaft part fits on the column, and the shaft you have to cut to fit. This style joint replaces the stock joint as well.
You can also use this adapter - you keep the stock joint on the column, and this goes between box and joint.
