It is currently Sun Nov 22, 2026 4:35 am
 Post subject: Fuel pumps
PostPosted: Fri Aug 10, 2007 8:22 pm
Any particular preferences as regards fuel pump manufacterors/sources for a stock carburated 225 circa 1970? Seems to be a wide range of quality with basic replacement parts(pumps,filters,bulbs,switches ect.) these days.Vehicle isn't in regular use but over full crank-case with too thin oil with strong oder of gasoline indicates failing pump? All input appreciated. Thanks.
PostPosted: Fri Aug 10, 2007 8:26 pm
Well, overly-full crankcase with strong smell of fuel does usually indicate a defective fuel pump, but if your '70 is a California model with the carburetor's fuel bowl vented via a hosepipe to a fitting on top of the fuel filter's body, a grossly flooding carb or a badly defective fuel tank vent can cause the same problem. Most all the slant-6 pumps available today are the same (except for the '70 California + '71 all-states/Canada w/that extra fitting); there's just one company making them and all the brands just buy from that company, as it seems. I'm sure there's extra-cheap junk from China coming in, so do try to stick with a reputable brand. Blackstone or Carter or TRW or NAPA...
PostPosted: Sat Aug 11, 2007 5:51 am
Dan and Achille,
I have recently been thinking about using an in-tank or electric in-line pump . Reason is I'm gonna have stuff off the block to swap cams and if pump is off, now would be a good time to block the pump hole and change pumps.
Now this is a case of fixing what isn't broken if there ever was such a case, but I do that fairly often to see the effect. I haven't found a slant six pump hole plate but could make one easily enough, but wonder if a 318 plate will do as well? And if there is a favored in-line or in-tank pump?
thanks
rock
'64d100
PostPosted: Sat Aug 11, 2007 6:38 am
Y'ask me, electric pumps are a damnuisance to wire up, mount, and set up correctly and safely on carbureted cars.
PostPosted: Sat Aug 11, 2007 7:48 am
I believe there are 2 or 3 sizes of fuel pump flanges that cover a majority of engines. The one I used was offically labeld for a jeep 4.0 which I think is also same for a SBC - take a gasket with you and go to auto parts store, in same section where they have the flashy chrome doodadds like hose coverings they usually have these as well.
Walbro pumps are good - www.apeusa.com
PostPosted: Sun Aug 12, 2007 12:57 pm
Dan and Achille,
thanks
rock
'64d100
I put a big block Chevy block-off plate on mine. Fits perfectly.
It seems that American engines from the 1960s used only two different fuel pump patterns: the small block Chevy, and everything else. While other pump parts such as the lever arm were different, the flange design is the same for a small block Mopar, slant six, big block Chevy, or most Fords. I guess they all bought their fuel pumps from the same sources.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
Users browsing this forum: No registered users and 16 guests
