It is currently Sun Nov 22, 2026 6:25 am
 Post subject: Carter BBD year question
PostPosted: Sun Aug 12, 2007 4:05 am
Hey I am looking at a Carter BBD on ebay in need of a rebuild and I was wondering if anyone could tell me the year. Here are the numbers that are listed 0-2681 on main body and 6-2318 on top half. Thanks.
1956 Dodge D100 Pick up
power plant 225 slant six
PostPosted: Sun Aug 12, 2007 8:12 am
No tag on the screw? You are screwed. Doe it have a flat tin cover over the bowl?
I have bunches of BBD's. None have tags.
Tin top ones are the newer ones.
Here is a place to check carbs. www.moparfins.com It has lots od BBDs listed.
PostPosted: Sun Aug 12, 2007 8:51 am
As rug_trucker says, the casting numbers you give are indeed not useful for identifying the carb. What is the eBay item number?
PostPosted: Mon Aug 13, 2007 3:19 am
Thanks Guys, I apperciate the help, but I am just about feed up with my Slant and I do not think I will be putting any more money in it. I have been having over heating problems and they countinued yesterday on the way to a show. I have changed replaced the radiator with a new one put in a new 185 thermostat and a 195 replaced all the hoses and it still runs HOT!! It may have a blown head gasket or a warpped head. I hate to say it, but after this season I am looking at installing a 318 with a rebuilt A904.
