It is currently Sun Oct 18, 2026 2:26 pm
 Post subject: converter
PostPosted: Thu Jun 20, 2002 3:46 pm
HELP, I'VE JUST GOT MY SECOND CONVERTER FROM MOPAQR PERFORMANCE THAT DOESN'T FIT. I HAVE A '67 DART WITH A 904. I ORDERED A 2500 STAHL FOR A 904 BUT THE THING DOESN'T FIT INTO THE CRANK(THE FIRST ONE THEY SENT WAS A LOCK-UP PUT IN THE WRONG BOX). ANY HELP WOULD BE GREATLY APPRECIATED.
alandnicole@shaw.ca
 Post subject: Re: converter
PostPosted: Thu Jun 20, 2002 4:12 pm
: TO RESPOND TO MY OWN PROBLEM, THE CRANK JOURNAL SIZE CHANGED IN LATE '67 OR '68. BUT THAT MEANS I STILL NEED A CONVERTER, CAUSE I'M NOT CHANGING THE CRANK!
alandnicole@shaw.ca
PostPosted: Fri Jun 21, 2002 6:41 am
: HELP, I'VE JUST GOT MY SECOND CONVERTER FROM
: MOPAQR PERFORMANCE THAT DOESN'T FIT. I HAVE
: A '67 DART WITH A 904. I ORDERED A 2500
: STAHL FOR A 904 BUT THE THING DOESN'T FIT
: INTO THE CRANK(THE FIRST ONE THEY SENT WAS A
: LOCK-UP PUT IN THE WRONG BOX). ANY HELP
: WOULD BE GREATLY APPRECIATED.
You will need a custom unit, or at least one with the small snout. I think Chad has one for sale, or you can order one from a place like Midwest converters.
PostPosted: Fri Jun 21, 2002 7:38 pm
: You will need a custom unit, or at least one
: with the small snout. I think Chad has one
: for sale, or you can order one from a place
: like Midwest converters.
: Lou
I just ordered one from midwest talked to the owner Dennis he was very helpful ran my whole setup through his computer to build me the right converter. I think There the easyest people to deal with i've seen.
melam@nxs.net
PostPosted: Fri Nov 01, 2019 3:06 pm
Car Model: 1962 plymouth valiant
'67 -'68 TRANSITION YEAR: THE HUB FOR( THE '67 & EARLIER) CONVERTER IS AN 1/8TH INCH SMALLER THAN NEWER CRANKS.
USE A RING TO COMPENSATE FOR DIFFERENCE BY HAVING A MACHINE SHOP ZING ONE FOR YOU. TAKE A MEASUREMENT FROM
HUB & SHAFT HOLE AND YOU ARE IN BUSINESS !!
Users browsing this forum: Amazon [Bot] and 14 guests
