It is currently Mon May 25, 2026 10:34 am
 Post subject: '72 automatic
PostPosted: Mon Aug 13, 2007 11:15 pm
I bought an 88,000 mile engine and automatic transmission out of a duster a while back but dont need the transmission. The guy I bought it from said the car ran great but he was putting a v8 in it. If anybody wants the transmission let me know. Just come get it. I was there when he pulled the engine out and saw the transmission fluid and it didnt look or smell burnt. The transmission is in New Smyrna beach, Florida.
PostPosted: Tue Aug 14, 2007 3:45 am
I'm interested. How much do you want for the trans? I'm close enough, to pick it up.
PostPosted: Tue Aug 14, 2007 5:51 am
You can have it if you want it. I have absolutely no use for it .
PostPosted: Tue Aug 14, 2007 8:02 am
OK, I'll take it. PM me your phone number and a good time to call, and I'll make arrangements to pick it up.
PostPosted: Tue Aug 14, 2007 9:48 am
Dam Charlie. Your quick on the draw. :cry:
PostPosted: Tue Aug 14, 2007 11:17 am
Like they say in Drag racing, "you snooze, you lose". :lol:
Bren, do you need the trans? I was going to keep it for parts, and/or future project. I can use it, but if you need it for your car, go for it. I am not in a hurry for one, and can wait for the next one.
PostPosted: Tue Aug 14, 2007 11:35 am
Not really. It would be a spare that has a large input shaft. It sounds like its a working transmission id be ashame to tare it down. If I got it now I'd likely rebuild it or use it for parts to lower the cost of my trans rebuild. I'd say you found it first, its yours.
PostPosted: Tue Aug 14, 2007 1:11 pm
What you really need for good parts is a 318 trans. That will give you the big input and pump too, plus the 4 disc clutches and 4 pinion steel planetaries. :D
 Post subject: 4 disc set-up
PostPosted: Tue Aug 14, 2007 5:06 pm
Hey zilla-- are you sure all slant 904's have the 3 disc style? My 62 FSM< says the 225 cars also have the heavier 4 disc set-up-- the 170 cars have the 3. Just curious as this is printed matter & not real world expereince.
On another note do any parts from a 727 swap with a 904? thanks Lawrence
 Post subject: Re: 4 disc set-up
PostPosted: Tue Aug 14, 2007 6:16 pm
Every 904 that I have seen come apart from a Slant has had 3 disc clutches and 3 pinion planetaries.
About all that will easily swap from a 727 is the valve body.
PostPosted: Tue Aug 14, 2007 6:30 pm
SSRN National Champion
That is why I have a Chrysler transmission expert to build my transmissions. Damn he is good. Thanks Ron Parker :D
Im Thinking About St Louie
