It is currently Mon Nov 23, 2026 12:11 am
PostPosted: Thu Aug 16, 2007 8:50 pm
Was under the car today (oil,filter & lube) and noticed that the exhaust pipe is over the point where the pitman arm connects to the center link and there's hardly any clearance.... (actually looks like there's a designed dent in the pipe for clearance (but no signs of contact ))
Is that normal or has the engine mount sagged? (alot or just a little)
PostPosted: Sat Aug 18, 2007 11:20 pm
Bump........
nobody knows how much clearance there should be from the exhaust (or K-member)...... :?: :shock:
The mounts aren't broke, and I don't have any problem replacing them if needed, but I don't want to replace them and not have anything change........
Users browsing this forum: Google [Bot] and 13 guests
