It is currently Fri Jan 02, 2026 4:37 pm
PostPosted: Tue Aug 21, 2007 8:01 pm
Hey all,
I am totally new here and I am working on plans for my first /6 build. I recently bought a 66 Valiant with a 170 in it.
I've been reading this site for a couple of months as well as various books and web articles. This has led to many questions :shock:
One of the many things I was wondering is whether or not it is possible to drill out the drain holes in a small spark plug head, big enough to get the lifters out if you want to?
Am I asking one of those questions where all the experience guys roll their eye here :roll: If so I appologize in advance!!!
Cheers,
Chris E.
PostPosted: Tue Aug 21, 2007 10:04 pm
:roll: :roll: :lol: ...
Why not use a 81 and up hydraulic engine "wide valve cover" head?
Those have a larger push rod hole which makes "head on" lifter removal possible.
Why will you need to remove the lifters after the engine is in the car? :?
PostPosted: Thu Aug 23, 2007 7:39 pm
DD,
That is exactly why I asked the question:) thank you.
If I used the 81 up head I would still get the "better" combustion chamber and the hardened valve seats.
I would just have to use the older rockers and hardware right?
As for removing the lifters in the car I was thinking about trying a medium wild cam. I figured if I didn't like it, it'd be easier to change in the car.
C
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Thu Aug 23, 2007 8:25 pm
DD,
C
The 81-up head will require it's own valve cover and also the rear bolt for the rocker shaft.
I have found that on a Slant car it is much easier to install and degree a cam with the motor out. It's just not that hard to pull a Slant motor out. :shock:
PostPosted: Thu Aug 23, 2007 8:58 pm
I 2nd Slantzilla. I will never again pull an oil pan or timing cover off a slant with the engine in place.
PostPosted: Thu Aug 23, 2007 9:05 pm
Me three.
