It is currently Fri Jan 02, 2026 4:11 pm
 Post subject: slight stut-tt-er
PostPosted: Fri Aug 24, 2007 9:44 pm
O.K, My engine runs great at idle, maybe misses a little once in a while.
But when I run it up to about 1800/2000 it has a bad miss. What could be wrong? The motor is all fresh re-build. Holley 1920.
Could loose lash cause this? (I think it might be a little loose)
The motor shakes visably when it starts making racket. It never "purrs like a sewing machine"... more like "Top Fuel Briggs & Straton". :roll: Timing might be a hair off, but It's real close, because alternately gets smoother, and rougher. Maybe it needs a dizzy recurve?
I'm puzzled, and any suggestions are welcome. What's the first and second thing that pops in you head?
A little on the build:
All stock style induction/exhaust(Still no muffler)
264 cam....0.100 off the block
Bowl ported heads/stock valves
point ignition/Accel Supercoil/new wires/NGK plugs
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Sat Aug 25, 2007 6:41 am
points ignition/higher compression
Im sure you need a recurve......my build is similar and required a very different curve from the stock EI curve.
PostPosted: Sun Aug 26, 2007 1:30 pm
Thanks, I asked someone else yesterday, and they said the same thing.
Any particular ignition conversion kit to get/stay away from?
I guess a recurve will be next.....
Thanks!
PostPosted: Sun Aug 26, 2007 7:03 pm
Well...here what I did....
I had been running stock EI for years ....just dump a 70s dist into whatever slant dist hole got in my way. They all ran fine.
I went to Las Vegas and helped Doug recurve a dist....then I helped somebody else(this time I was the expert).
I came back from Vegas and started swapping springs and test driving. It took me all day but I got a curve that was far and away better than anything I had tried before(stock 65 Valiant Prestolite dist) I limited the mechanical advance to get my intial and total where I wanted them . I used a pop rivet in the advance slot.
Get a pile o springs and a 6 pack of red ale......and a Yardbirds tape. Start early.
PostPosted: Sun Aug 26, 2007 7:40 pm
Hmm? Whazzat? :D
 Post subject: Which Version?
PostPosted: Sun Aug 26, 2007 8:36 pm
That's slant modifying music...pick your fav guitarist from the band's past, and recurve... (Keith Relf, Paul Samwell-Smith, Chris Dreja, Jim MacCarty...and add one of the following guitar kings below)
"For Your Love" - Eric Clapton
"Over Under Sideways Down" (Having a Rave Up) - Jeff Beck
Roger the Engineer - Jeff Beck
"Happenings Ten Years Time Ago" - Jeff Beck and Jimmy Page
Little Games - Jimmy Page
Live at the Anderson Theatre - Jimmy Page (pre- led zeppelin version of 'Dazed and Confused')
Last Rave Up - Live at the Shrine Auditorium June 30-July1, 1968 (long version of Dazed and Confused, Page's version of 'Beck's Bolero'...hard to find bootleg now...)
Sorry, been 'archiving' my vinyl with a USB turntable....
"Yeah I got that, too..."
Got both Box of Frogs albums?
 Post subject: Recurve
PostPosted: Mon Aug 27, 2007 9:01 pm
BigBlockBanjo,
Now that my rebuild is finally breaking-in, (16,000 miles), I am finding that I have a stutter too. If I ease on the throttle, it stutters between 1200 and 2000. If I give it a little more gas it clears up. I am running a little rich (#57 jet). If I punch it you never notice, only at light throttle settings. At 2000 rpm the stutter goes away. If I punch it the tires break loose, and no stutter....
I am going to try a lighter MOPAR DCC-2932675 spring, same as the MRG-925B springs, and leave the heavy stock looped spring in there to see if it will clear up. I am thinking it needs a little more advance. I am at 20 degrees initial. The idle is fine at 750, a little lopy in gear at about 600 rpm.
I have a few intake leaks that developed which maybe contributing factors. Need to install the Aussie carbon fiber intake/exhaust gasket.
Let me know how it goes....
