It is currently Thu Jan 01, 2026 7:18 am
PostPosted: Sat Aug 25, 2007 4:55 pm
Hey All,
First off I was wondering if anyone could identify the wire with the gray connnector in the bottom left of this pic. It goes all the way down to the transmission. Would this be where the Neutral Safety Switch wire goes?
Also wondering if anyone can identify this carb for me. I've got to get some screws and linkages for it at the junk yard this week.
Thanks much!
Chris E.
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Sat Aug 25, 2007 5:12 pm
Carb is a Carter BBS. Wire is probably Neutral Safety Switch. Use a test light or continuity meter to test for ground with trans in Park or Neutral, open (no ground) in any other gear.
