It is currently Wed Dec 31, 2025 7:59 am
PostPosted: Sun Aug 26, 2007 7:21 pm
The pin that my passenger side no draft rotates on snapped. I can't get the snapped pin out of the door. There is enough of it left to get a set of pliers or vise grips on. Ive tried rotating and pulling up but no luck. Can anyone tell me how to remove this pin ?
thanks,
225, pushbutton 3spd
'63 dodge dart hardtop
PostPosted: Sun Aug 26, 2007 7:44 pm
Your passenger side...which, now? Do you mean the vent wing window? Never heard it called a "no draft" before. Doesn't mean it's wrong, just an interesting term. Whereabouts are you from?
You will probably find you need to remove the door trim panel (not difficult) and work from inside the door.
PostPosted: Sun Aug 26, 2007 8:47 pm
Yeah, you got it! I am talking about the vent window. Im born and raised in Ontario. "no draft" is a term I picked up from hanging around car shows. I took the door panel off but I may have to remove the window crank and door handle mechanism to get some room for my hand in there.
PostPosted: Sun Aug 26, 2007 8:51 pm
How 'bout that, I'm in Toronto myself.
The door handle mechanism is easy to remove. Window regulator is a little more complicated than that. Have you got the factory service manual for the car?
Users browsing this forum: Ahrefs [Bot] and 7 guests
