It is currently Sun Oct 25, 2026 10:04 pm
 Post subject: milling the block
PostPosted: Fri Jun 28, 2002 12:16 pm
How much can safely be milled off the top of the block, while retaining block strength? Thanks
sschultz@telusplanet.net
 Post subject: Re: milling the block
PostPosted: Fri Jun 28, 2002 9:30 pm
: How much can safely be milled off the top of
: the block, while retaining block strength?
My guess: More than an inch off an iron 225 block.
redbear@vrx.net
PostPosted: Fri Jun 28, 2002 11:54 pm
: My guess: More than an inch off an iron 225
: block. (sounds like a "do it yourself" 170) =: - o
I have taken .150 off the block deck, no problems.
Remember that the Alm 225 has *no* top deck but yes, those have head gasket sealing problems.
One little trick is to plug deck holes, flip the block up-side-down and use some block filler to help back-fill the deck area. (just an inch or so thick, it get's real hot up there so don't get crazy with the filler)
Users browsing this forum: Bing [Bot], Plymouth_Ruster and 9 guests
