It is currently Thu Jan 01, 2026 5:53 am
 Post subject: Voltage Regulators?
PostPosted: Mon Aug 27, 2007 10:02 am
I have been using the Mopar DCC-4529794 voltage regulator the last couple of years, but notice that they fail too often for me. Is there a better replacement? Summit has a listing for a Standard Motor Products VR125 which costs twice as much. Is it a better voltage regulator?
This is an electronic ignition vehicle.
What does everyone else use?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Mon Aug 27, 2007 12:18 pm
My experience with the MP voltage regulators (early and late type) has been poor. Maybe they're buying them from the same company providing the ignition orange boxes! :shock: The MP unit on my '62 is the same 4529794 you've been using, and it's held up OK for now, but that car doesn't see a lot of use right now.
The Standard VR-125 is a good unit, as is the Echlin VR-38. As for cost...Summit are gouging on the Standard part, which can be had for under $31 from www.rockauto.com , and you may also want to check locally, since Standard/Bluestreak and Echlin are widely available without shipping charges.
Do make sure your regulator has a good ground...scrape paint off the regulator base and run a ground loop to the alternator housing and battery negative terminal, if necessary.
 Post subject: Homemade
PostPosted: Mon Aug 27, 2007 12:56 pm
I ended up making my own..............
http://www.slantsix.org/forum/viewtopic.php?t=22124
http://groups.msn.com/EdSvitilsSportste ... lator.msnw
