It is currently Sun Nov 22, 2026 9:21 pm
 Post subject: EGR Block off plate
PostPosted: Wed Aug 29, 2007 1:13 pm
Who sells EGR block off plates?
Checked the parts for sale section, none to be found?
I would like to purchase one plate and one gasket for my engine.
Thanks,
PostPosted: Wed Aug 29, 2007 1:15 pm
Usually, the procedure for an EGR blockoff on a slant six is simply to remove the hose from the vacuum diaphragm and cap whatever the other end leads to...
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Aug 29, 2007 1:24 pm
Done that........I want to make sure it is not partially stuck in the on position.
PostPosted: Wed Aug 29, 2007 2:31 pm
Dealer item, p/n 3671 447, used with standard EGR valve gasket p/n 4173 167.
PostPosted: Wed Aug 29, 2007 2:58 pm
Or make your own.
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Wed Aug 29, 2007 3:05 pm
Recommend using 1/4" (0.250") material, rather than 1/8" (0.125") for flange rigidity and sealing.
Users browsing this forum: Bing [Bot] and 8 guests
